#1 2007-07-04 10:16
ozzii
Rules pane does not remember its height
The rule's pane doesn't remember his height.
After every start, the size showing just 4 rules.
_________________
#2 2007-07-06 16:51
Re: Rules pane does not remember its height
It's not a bug, it just the way it works smile
I will make it remember when I get a chance...
#3 2007-07-07 09:39
ozzii
If it's not a bug, maybe an option to select the way it works (remember or not) roll
_________________
#4 2007-07-16 23:42
sirjack
I think the ozzii's suggestion is to avoid loading a saved preset every time (as i have always to do).
A simple solution could be to automatically save the current configuration as a hidden default preset when exiting the program, and automatically reload it when starting again.
#5 2007-07-24 19:27
ozzii, latest dev version now remembers the height of the rules table (if you use "remember last position and size" option): ReNamerBeta.zip
sirjack, I think you misunderstood his suggestion (your suggestion is already implemented, look into settings).
#6 2007-07-25 05:07
ozzii
Thanks big_smile:
_________________
