#1 2024-08-05 13:54
rghilton
removing random DocID (12 digits including 2 hyphens)
Hi all
Another newbie here.
Can anyone assist with removing a random 12 number sequence (example: 1256-4587-9658) from a file name?  The number sequence wont always be in the same position of the file name but will always be in the same format of ****-****-****
Thank you!
#2 2024-08-05 15:19
rghilton
Re: removing random DocID (12 digits including 2 hyphens)
Worked it out via ChatGPT.  -  _\d{4}-\d{4}-\d{4}
#3 2024-08-05 15:45
That's correct.
You can use the Regular Expressions rule to replace "\d{4}-\d{4}-\d{4}" pattern with an empty string.
