#1 2024-10-02 11:11
Carlos_1959
Space out CamelCase words
I need your help with the following:
I have several files where the file name is in this text example ‘aaaabbbbcccc’ and I want to rename them to ‘aaaa bbbb, cccc’.
What kind of rule can I make?
EDIT:
For example, convert "BeachPiriapolisUruguay.jpg" to "Beach Piriapolis, Uruguay.jpg".
#2 2024-10-03 14:06
eR@SeR
Re: Space out CamelCase words
Try RegEx rule:
1) Regular Expressions: Replace expression "^((.)\2+)((.)\4+)((.)\6+)$" with "$1 $3, $5" (skip extension)
aaaabbbbcccc
aabbcc
abc
aabbc
aabcc
abbcc
aaaabbbbccccdddd
To:
aaaa bbbb, cccc
aa bb, cc
abc
aabbc
aabcc
abbcc
aaaabbbbccccdddd
- it is applied only for 3 repeated groups of characters as per given example
- filenames with non repeated characters of 3 groups should be ignored
Please provide feedback if it works as expected.
P.S. Please write more descriptive topic name next time.
#3 2024-10-03 16:44
Carlos_1959
Didn´t work or I don´t know how to do.
This is the file name and what I want.
Can you try for me?
Thank you
#4 2024-10-04 04:59
blackvoid
Hard to work out what you want from the first post.
From your example filename, this should work as long as there are three words and they start with a capital letter.
Add rule, choose 'Regular Expressions'.
Add the following :
Expression : ^([A-Z][^A-Z]*)([A-Z][^A-Z]*)([A-Z][^A-Z]*)$
Replace : $1 $2, $3
Case-sensitive : make sure its ticked.
Skip extension : make sure its ticked.
Save rule.
#5 2024-10-04 10:27
Carlos_1959
It worked. Thank you
And I apologise for not explaining correctly what I wanted in my first post.
#6 2024-10-04 10:36
It's worth noting that there is a built-in option in the Clean Up rule to "Insert a space in front of capitalized letters (e.g. CamelCase)".
This option will add spaces between words, but it won't insert a comma after the 2nd word, so it's not a complete solution.
#7 2024-10-04 19:02
Carlos_1959
Thank you
