#1 2025-03-19 01:02
E. Gregious
Can the user data folder be moved?
I've searched the ReNamer forum and the User Manual and can't come up with any hits on this:
Is there a way to move the den4b folder to somewhere other than ...\OneDrive\Documents?
#2 2025-03-19 11:27
Re: Can the user data folder be moved?
If you are using the installer version, your application data would normally be stored in the user profile directory, which in your case appears to be "OneDrive\Documents".
You can change where ReNamer stores this data by editing the Storage.ini file located in the installation folder.
See this article for more details: https://www.den4b.com/wiki/Application_Data_Storage
#3 2025-03-19 20:31
E. Gregious
It appears that changing the storage.ini location solved the problem.
For some reason, the Presets folder and one or two others were in the OneDrive\Documents folder. The others were duplicated in the %userprofile%\Documents\... folder, but the Presets folder was only in OneDrive\Documents. I modified storage.ini, moved the Presets folder into the userprofile branch, and all seems well.
Thanks for your prompt help.
#4 2026-02-26 22:59
skiwi
I changed storage.ini (Windows) from the default "#USER#"  to "#USER#%USERPROFILE%\My Drive\Downloaded\Renamer\".
Then copied the files and folders from in "C:\Users\User\Documents\den4b\ReNamer\" across to "C:\Users\User\My Drive\Downloaded\Renamer\".
Renamer seems to interpret this as "C:\Users\User\Documents\den4b\ReNamer\C:\...\My Drive\Downloaded\Renamer\"
It would be great if this was user configurable from 'Settings'.
#5 2026-02-27 09:07
You have to choose either #USER# or %USERPROFILE% as your path basis, because they both represent an absolute path.
In your case, you need to use "%USERPROFILE%\My Drive\Downloaded\Renamer\".
#6 2026-03-10 20:54
skiwi
ah, thanks, I assumed #USER# was the functional tag for the line
