#1 2025-04-15 02:46
visusys
Replace Rule: Ability to specify unicode ranges in wildcard brackets?
I have the following "Find" entry in a replace rule:
[a-z0-9]&[a-z0-9]
, and the "Replace" entry is
$1 & $2
. This effectively pads ampersands with spaces when they occur immediately after and before an alphanumeric character.
Example:
Equinoxe Brass&Strings-00-Equinoxe Brass&Strings-037-Equinoxe Brass&Strings C#1-C#1.wav
Becomes:
Equinoxe Brass & Strings-00-Equinoxe Brass & Strings-037-Equinoxe Brass & Strings C#1-C#1.wav
But I want to expand the wildcard character class to include all valid windows characters, which can consist of any Unicode character except for a few illegal characters.
For reference, the illegal characters are:
How can I modify my find character class from [a-z0-9] to include all valid Unicode characters? I want the rule to also be compatible with filenames that contain unicode characters and not just alphanumeric characters.
Is this possible?
#2 2025-04-15 21:25
Re: Replace Rule: Ability to specify unicode ranges in wildcard brackets?
Why don't you use word boundary or word character classes?
Expression: "\b&\b"
Replace: " & "
Expression: "(\w)&(\w)"
Replace: "$1 & $2"
These will work just fine with Unicode text.
