#1 2025-06-05 11:16
Sequencer1
How do I rearrange only if there's an exact match?
Hi all,
I couldn't find a thread with this question, so apologises if it has been asked already.
I'm looking to rearrange specific numbers/text, only if it matches the input exactly and isn't part of a larger section.
Example:
Text 123.wav
to
123 Text.wav
I have somewhat achieved this already by using the rearrange function with the following settings:
Split using: "Exact pattern of delimiters"
Pattern: "|123"
New pattern: "123 $1$2"
However, it will also move the matched "123" even if it's part of a larger sequence/word.
Example:
Text 1234.wav
to
123 Text 4.wav
As you can see, it ends up rearranging the 123 away from the 4, which I don't want. The same applies to words.
So I'm trying to move text only if it isn't going to break a larger number sequence or word.
Thank you
#2 2025-06-05 14:57
Re: How do I rearrange only if there's an exact match?
The Rearrange rule is not suitable for your task, but the Regular Expressions rule is.
Replace expression "(.*)\s+(123)\b" with "$2 $1".
#3 2025-06-05 15:43
Sequencer1
Ah brilliant, yes that works.
Much appreciated and thanks for the response den4b
smile
