#1 2025-07-25 11:47
reframer
Adjust name and take parts from the existing name
Hi all,
I have a filename:
The_Test_Article_No_31_from_22._July_2025
This academic article comes every week or month, so I want:
The Test - 2025-07-22
The easy way would be:
- Insert: The Test - 2025-
And now the rest:
- Find January in the name and replace it with 01
- Or find February in the name and replace it with 02
- And so on
And
- Find any 2 digit number and dot
- Replace it with only the 2 digit numer / delete the dot
- So from 22. to 22
Happy to get some help.
#2 2025-07-25 17:50
Re: Adjust name and take parts from the existing name
This can achieved using the following rules:
1) Clean Up: Replace with spaces "." "_", Normalize spaces, Fix spaces (skip extension)
2) Regular Expressions: Replace expression "\s+Article No\s+\d+\s+from\s+" with " - " (skip extension)
3) Reformat Date: Convert to "yyyy-mm-dd" from "d mmmm yyyy", whole words only, skip extension
Input:
The_Test_Article_No_31_from_22._July_2025.pdf
Output:
The Test - 2025-07-22.pdf
#3 2025-07-27 08:22
reframer
Wow, first of all thank you very much for the quick support.
Second, I learned a lot here, again. I think my biggest weak point is the regular expression. Since I don't know its power and many options, I try to create solutions without using regular e.
I tried many times a "how to learn regular expressions" wiki but without success.
Third, I did not know that the function date with mmmm is a written format of a month.
Finally, a new question here:
Imagine the example from above:
However, it can also be like:
The_Test_SpecialArticle_No_31_from_22._July_2025.pdf
Or
The_Test_LongMagazin_from_22._July_2025.pdf
And so on. And the output should always be like:
In your solution from above:
The "Article No" is explicitly mentioned.
But is there a logic to say "any word other than The_Test should be deleted"?
#4 2025-07-27 11:19
Since we don't know what the variable part can be (e.g. "Article_No_31", "SpecialArticle_No_31", "LongMagazin") then you have to find a common delimiter, which appears to be "from" followed by a number.
In this case you can delete everything from the start up to "from" using the Delete rule, or delete everything from the start up to "from" followed by a number using the Regular Expression rule, for extra validation.
Regular Expressions rule: Replace expression "\A.*?\s+from\s+(?=\d+)" with "The Test - " (skip extension)
Input:
Output:
#5 2025-07-30 11:11
reframer
Dear Admin, thank you again for the quick support.
I try to understand and learn this logic. I got the way of "common delimiter".
But here comes the - I think - final challenge for you: Without having a common delimiter.
Input:
The_Test22.July2025.pdf
The_Test22July2025.pdf
The_Test_22._July_2025.pdf
The_Test_22_July_2025.pdf
The_Test_22_07_2025.pdf
TheTest22725.pdf
Wished output:
Here I could again do not find a solution for that.
#6 2025-08-03 09:28
In that case your best bet is to focus on the dates.
Isolate them, reformat to a common format, and strip away everything else.
If you would like to get additional guidance, please consider purchasing ReNamer Pro.
