#1 2025-09-05 08:18
DavidBrocho
Average Network Transfer: time to calculate?
Good morning, I'm using average network traffic for 30 minutes.
Is the average time you calculate the entire event time (30 minutes) or a predefined unchangeable time?
It is important for me to know what time range the average is in order to define the field of KB downloaded over that entire time.
Is there a possibility of adding an option to the program to define this average time?
Thanks a lot!!
Congratulations on such an excellent program.
smile
#2 2025-09-07 08:46
Re: Average Network Transfer: time to calculate?
The actual measurement of the network usage is taken every second in all configurations.
If the averaging option is disabled, then all measurements within the configured period of time (duration) must stay below the threshold in order to trigger the event.
If the averaging option is enabled, then the average of all measurements within the configured period of time (duration) must stay below the threshold in order to trigger the event.
I think this should address both of your questions.
#3 2025-09-09 21:48
DavidBrocho
THANKS!! YES. I understand.
