#1 2025-10-17 22:47
chingilou
Problem with v7.8 Reformat Date: Convert to "(yyyy)" from "yyyy"
in version 7.8 and 7.8.0.1 beta i have problem in Reformat Date: Convert to "(yyyy)" from "yyyy", whole words only, skip extension
01 is considered as year and renamed 0001
in version 7.7 it works perfect but not in the new one
#2 2025-10-20 23:36
chingilou
Re: Problem with v7.8 Reformat Date: Convert to "(yyyy)" from "yyyy"
OK, I found a solution with RegEx: Replace the expression "\(?(\d{4})\)?" with "($1)" (skip the extension), but it only prevents the Reformat Date command: Convert to "(yyyy)" from "yyyy", whole words only, skip the extension. fixes the problem in older versions.
Nevertheless, I found a solution.
#3 2025-10-23 11:33
The date-time parser has undergone significant refactoring in v7.7.0.2 Beta, adding several new features and also becoming a bit more flexible.
The "yyyy" pattern is defined as 1-4 digits long, so that is why "01" is interpreted as a year. Perhaps this extra flexibility is counterproductive here.
We'll get this addressed in the next version.
#4 2025-11-04 23:03
This issue was addressed in v7.8.0.2 Beta:
Enforce a minimum required number of digits for date/time pattern tokens in the Reformat Date rule.
#5 2025-11-05 01:11
chingilou
smile thanks
