#1 2025-11-08 16:48
CoolRaoul
Shutdown tasks fail
Here's my first profile:
condition:
1) User Inactive: Active after inactivity for 0:10:00 using Last Input Event
Actions:
1) Run Program:  c:\bin\psshutdown.exe -k -t 60 -c
2) Shutdown: Not forced
Note : there are two different kind of "shutdown" actions because of my tests. Anyway, none worked
"shutdown" actions fails with "error"
"run program" action fails with "failed to execute
#2 2025-11-09 09:45
Re: Shutdown tasks fail
The most common reason why the Shutdown action fails is because some application or a service blocks it, preventing the shutdown operation.
Have you tried using the Shutdown action with the Force option enabled?
Essentially, don't allow the running applications/services to prevent a shutdown.
#3 2025-11-09 10:05
CoolRaoul
I'm going to test this right now and keep you informed.
But what about "Run Program" action which fails too ?
#4 2025-11-09 10:41
CoolRaoul
I thing i'm going to give up: now it won't even trigger, even when the delay has passed.
Here the actions are triggered only after having moved the mouse, the status "inactive for ..." keeps counting as long as I don't move the mouse or touch the keyboard whatever actions I put in the list.
#5 2025-11-09 18:05
CoolRaoul
I thought i had managed to make it work using that sequence:
  • conditions
    • User Inactive: Inactive for 0:00:20 using Last Input Event
  • actions
    • Play Sound: "CP70 Med B3.wav"
    • Run Program: shutdown /s
unfortunately, on my desktop W11 machine, the shutdown command (either built-in or windows native "shutdown") is not executed as long as the session is locked.
My objective is to have the computer shutdown by itself in any case of inactivity even when user is away (but still logged in).
#6 2025-11-09 18:58
There are several issues with your configuration.
1. You must enable the Force option in the Shutdown action, if you want to shutdown the machine while the session is locked.
2. The User Inactive event will keep running past the specified time if you have the "Trigger when user becomes active" option enabled. You probably don't want that option enabled.
3. Avoid using PsShutdown tool unless you really know what you are doing. In your screenshot, the set of options "-r -k -c" is invalid. Execute the same command manually in the Command Prompt to test it. Also, if you enable the "Wait until execution finishes" option in the Run Program action, it will display an "Error" status when the tool returns a non-zero exit code, i.e. an issue with the program.
#7 2025-11-09 19:05
CoolRaoul
Already tried without success but I'm going to check again then.
that was my previous mistake, but I've fixed it now.
The main issue is that PsShutdown  requires administrative privileges and that Shutter runs the command in normal mode. That's why I've now switched to native windows "shutdown" command as you should have noticed in my last post "Run Program: shutdown /s"
#8 2025-11-09 19:18
CoolRaoul
It was probably another issue when I checked that at first with "Force" since when using that option it is now working fine with (even if I don't like preventing apps to make a graceful shutdown but that's another story)
