#1 2007-08-06 18:23
kgblossom
Replace and increment.
Hello, I have just started attempting to use this renamer. And after a few hours in I decide to post the question that is frustrating me. I have many files that need to be basically renumbered. These file look similar to this:
280B850Z_01.tif
280B850Z_02.tif
280B850Z_03.tif
280B850Z_04.tif
I need to replace the 280B850Z_01.tif file and increment it by 5 to make this file 280B850Z_06.tif. the 02 file to 07 and so on.
It appears to be simple I just can't figure this out.
Any help?
#2 2007-08-06 20:24
Re: Replace and increment.
Here is a list of rules that you need to use:
1) Delete from delimiter "_" until the end (skip extension)
2) Insert "_" as suffix (skip extension)
3) Serialize incremental from 6 step 1, pad to length 2, as suffix (skip extension)
P.S. Don't forget to sort by the Name column before you apply the rules.
