#1 2026-05-11 22:09
sdaughtry
Presets Manager improvements
Request 1: add a toolbar button, titled 'Presets', that when clicked would display the Presets Manager dialogue window
Request 2: when a preset is executed (via the Enter key or double left click of the mouse), automatically close the Presets Manager window
Alternatively, dock the Presets Manager window at the top right of the main window so it is displayed at all times. On my monitor, there is plenty of space adjacent to the rules window that could easily accommodate a docked Presets Manager window. I'd actually prefer this addition (versus the previous two), as I toggle between Presets a *lot* in my daily file management renaming needs...
As always, I appreciate your time and consideration!
#2 2026-05-17 21:55
Re: Presets Manager improvements
Thank you for your feedback and suggestions.
This will be added in the next version.
If you hold Ctrl key when loading a preset, it will automatically close the window, as mentioned in the Presets Manager documentation.
There are some technical reasons for opening the Presets Manager in modal mode (blocks all other windows), but it's an interesting idea.
In the meantime, you can access the Presets Manager quickly via the Ctrl+P shortcut, and soon via a toolbar button.
#3 2026-05-23 15:20
This feature has been implemented in v7.9.0.3 Beta.
#4 2026-05-23 18:11
sdaughtry
Thank you!!
