Hi ![]()
I can't tell if this is a bug or intended behavior. When I shrink the "Statement" column until it's completely hidden, it reappears upon restarting. Could you tell me if I can remove it, and also if I can customize the size and position of the other columns?
Thanks ![]()
It's not a bug.
The statement column get auto-sized on startup to fill the available space.
Currently, there is no option to remember column sizes between restarts.
