#1 Today 18:59
Elektro
Dark theme support — Feature request and contribution offer
Hi Denis,
I'm ElektroStudios, a VB.NET developer. Years ago, I shared my RegExCon tool on the ReNamer forums (here).
Recently, I've been contributing to third-party applications, mostly implementing customization features and usability improvements. Some examples:
These applications are written in very different programming languages, yet, with AI assistance, I've implemented changes, developed unit tests, and produced contributions of sufficient quality to be accepted.
Therefore, I believe Delphi/Lazarus wouldn't be an obstacle to implementing a dark theme. I'm familiarized with Pascal (Scripting).
As a regular ReNamer user, I'd love to see this feature, and I'd humbly offer to implement it myself, free of charge of course!.
I understand that ReNamer is proprietary commercial software. I'm only humbly requesting the minimum source files necessary to implement and test this modification. Just the source-files related to the UI where a modification like this should be applied; not a full compileable source-code. I'd then return the modified files privately to you. Could you privately provide me with your personal email address? (you can find mine in my user profile)
Alternatively, I'd kindly ask you to consider implementing a dark theme yourself, however, I know it is a thing I (well, the AI) could do in short time, even if it would require to write custom renderers or user-controls; and you probably have many other things to do with more priority than implementing this.
Anyway, if you can consider doing it yourself, please let me advice that one often overlooked detail is the native Windows title bar. The 'DwmSetWindowAttribute' API, using 'DWMWA_USE_IMMERSIVE_DARK_MODE' (attribute 19 or 20, depending on the Windows build), can darken it. This is important to prevent a bright white title bar from disrupting an otherwise dark interface.
Dark theme concept mockup:
Thank you for your time and for developing such a useful application.
I look forward to hearing from you!
Best regards,
ElektroStudios
#2 Today 19:17
Elektro
Re: Dark theme support — Feature request and contribution offer
Well, it turns out I hadn't updated my version of ReNamer in over a year!
I've just come across this post and downloaded ReNamer 7.10. To my delight, it already features a dark theme, including a properly darkened native Windows title bar.
Couldn't ask for more! Thank you very much, Denis.
I apologize for the irrelevance of my previous post. I'll leave it here anyway, just in case the mockup might serve as inspiration for any future visual improvements.
Thanks again, and keep up the great work!
Best regards,
ElektroStudios
