#1 Yesterday 22:50
Elektro
Dark theme: Improve readability of the blue text in the "New Name" col
Hi Denis,
First of all, thank you again for implementing the dark theme in ReNamer!
After using it for a while, I've noticed a significant readability issue with the bright blue text displayed in the "New Name" column.
The current blue is extremely saturated and harsh against the dark background. The contrast feels excessive, making filenames surprisingly difficult to read comfortably. Personally, I find it quite unpleasant and even visually exhausting, especially when working with long lists of files.
To be frank, this particular color is so uncomfortable that I'd prefer disabling the dark theme entirely rather than having to deal with it. I can't still with that harsh blue in dark for more than 5 seconds.
I don't mean this as criticism of your work. I genuinely appreciate the dark theme, but I believe this particular issue really needs to be addressed to make it comfortable for everyday use.
This can't be read, sincerely: w1xS4Ti.png
It reminds me of a Windows system color, such as HotTrack, which makes me wonder: are you restricted to using predefined system colors due to technical limitations?
That would be a shame, honestly.
Also, I remember reading your comment in the thread where you notice the release of the dak themed ReNamer, commenting about certain limitations imposed by the Windows color system in your UI components, which makes me suspect that this might be one of those cases.
Am I right, or is this color actually customizable? I find it hard to believe you would deliberately choose such an intense blue.
In any case, even if you're limited to predefined Windows system colors, surely there are several alternatives that would be preferable to a color that is practically unreadable against a dark background.
I would really appreciate it if you could reconsider this particular color and choose a more readable alternative. It would make a significant difference to the usability and overall comfort of the dark theme.
Suggested improvement:
Could you please consider replacing the current bright blue with a softer, less saturated shade?
For example, I experimented with a more subdued blue:
Suggested color: #5690D6
I've prepared a mockup showing how it could look:
Of course, the exact shade is entirely up to you. My suggestion is simply to use a more muted, eye-friendly blue that preserves the visual distinction of renamed filenames without being so aggressive against the dark background.
I believe this relatively small adjustment would make a substantial difference to the overall usability and comfort of ReNamer's dark theme.
I'd really appreciate it if you could consider this improvement.
Thank you for your time and continued work on ReNamer!
Best regards,
ElektroStudios
