#1 2007-10-20 14:21
coldcell
Problem: How rename folder with "."?
I have problems to rename or remove folders with "." in the foldername, any solution?
regards
#2 2007-10-20 14:39
Re: Problem: How rename folder with "."?
What kind of problem is it you are having?? I know that Windows doesn't not like "." (dot) in front of the name, but ReNamer can still rename folders with a dot, or put a dot in front of the name without any problems at all.
#3 2007-10-20 15:25
coldcell
ok. I have found "my" problem! With unchecked skip extension works my preset!
