#1 2007-10-25 20:35
kingfenix
Comic numbering
If you have files such as the list below, how can you rename them to all have 3 digit issue numbers?
Comic Name 1.cbr
Some Really Amazing Comic Name 002.cbz
Comic 08.cbz
TIA,
KF
#2 2007-10-25 21:28
Re: Comic numbering
Hi king,
at least you could do this with two regular expression search & replace:
For Comic Name 1.cbr
Search for
space => \s
on single digit => \d => in brackets () for back referencing (\d)
end of name => $ ........ to capture only the last digit in name like "test 2king 3 fenix 4.txt"
[x] Skip extension
Search: \s(\d)$
Replace with
space
two zero's => 00
the captured digit => $1
Replace: 00$1
For Comic 08.cbz
Search: \s(\d\d)$
Replace: 0$1
HTH?
#3 2007-10-26 09:19
Re: Comic numbering
You can use a predefined script from within PascalScript rule, which is called "Pad number sequences".
It does exactly what you need! To change the length of the new numbers - change PAD_TO_LENGTH constant.
#4 2007-10-28 15:21
kingfenix
Re: Comic numbering
Can you provide a example of the pascalscript to do so, I am afraid I dont know it very well
KF
#5 2007-10-28 15:22
kingfenix
Re: Comic numbering
DOH, sorry I understand now
KF
#6 2007-10-28 22:04
Re: Comic numbering
That script comes together with the distributive of ReNamer wink
Just in case, I post the full script which I have mentioned:
  PAD_TO_LENGTH = 3;
function CountDigits(const S: WideString; StartI: Integer): Integer;
var I: Integer;
  Result := 0;
  for I:=StartI to WideLength(S) do
    if IsWideCharDigit(S[i])
      then Inc(Result)
      else Break;
function MakeZeros(Count: Integer): WideString;
var I: Integer;
  Result := '';
  for I:=1 to Count do
    Result := Result + '0';
  Start, Count: Integer;
  Start := 1;
  while Start < WideLength(FileName) do
    Count := CountDigits(FileName, Start);
    if (Count > 0) then
      if (Count < PAD_TO_LENGTH) then
        WideInsert(MakeZeros(PAD_TO_LENGTH-Count), FileName, Start);
        Start := Start + PAD_TO_LENGTH;
      end
      else Start := Start + Count
    else Inc(Start);
