#1 2007-10-28 00:27
History for edit controls
I know i can save hole presets.
But often i want select an text or RegEx i have used some time before.
So i want to ask why have your edit combos now history?
I would find it nice to see the last 15 used strings in an drop-down list to select them later again.
Could you store them in the INI too?
like
[Settings]
[Last]
[MetaTags]
[Insert]
1=
2=
15=
[Remove]
1=
2=
15=
[Replace]
1F=
1R=
2F=
2R=
15F=
15R=
[Strip]
1=
[RegEx]
1E=
1R=
2E=
2R=
15E=
15R=
#2 2007-11-03 22:25
Re: History for edit controls
It is possible, but I have to consider the "effort vs advantage" factor...
I put it onto the TODO list, for later consideration, but do not guarantee its implementation.
Time is really precious these days...
#3 2007-11-17 13:23
Too bad, but i understand of course. Thank you wink
