#1 2007-11-05 18:05
PascalScript: Split / Tokenize / Wrap string into parts
How can i split FILENAME into parts at an given sign with PascalScript?
i.e.
we have FILENAME "some file name.txt"
and i want to split it with something like      x := SPlit(FileName, ' ')
to get
x[0] some
x[1] file
x[2] name
Pascals 'Wrap' give error in PascalScript.
I searched and found some code but nothing work with PascalScript.
// from  http://www.delphipraxis.net/topic27196_splitfunktion.html
function Split(const fText: String; const fSep: Char; fTrim: Boolean=false; fQuotes: Boolean=false):TStringList;
xxxxyyyyzzzz
  part: array of string;
part := Split(FileName, ' ');
  FileName := part[2];
end
#2 2007-11-06 13:07
Re: PascalScript: Split / Tokenize / Wrap string into parts
Have a look at the Help document for PascalScript rule. It lists all of the available functions/procedures and types (excluding basic data types like integers, strings, etc). I didn't register any classes like TStringList, because it means redeclaring all these classes/units for PascalScript. I prefer to keep all of the functionality to functions for several reasons, e.g. safer, more consistent, much less overhead, etc.
Anyway, you need to use this function below:
function WideSplitString(const Input, Delimiter: WideString): TStringsArray;
  I: Integer;
  Parts: TStringsArray;
  Parts := WideSplitString(FilePath, '\');
  for I:=0 to Length(Parts)-1 do
    // access each part via Parts[i]
#3 2007-11-06 17:50
I swear i have used the search function big_smile But obviously i am not able to do an correct search. roll Today i see it too.
I even not know what TStringList is, i have copied just the code.
So you wrote functions in Pascal and provide this us inside the ReNamer.exe?
lol Thank you.
#4 2007-11-06 19:06
Thanks tongue it works:
// Swaps FileName-parts at minus-sign.pas
  // sign where to split the file name:
  // f. ex. "Artist - Song.mp2" split at ' - '
  SplitSign = ' - ';
  // split the filename at '-' into parts:
    Parts := WideSplitString(WideExtractBaseName(FileName), SplitSign);
  // Note: parts are numbered from 0 on: 0, 1, 2, 3...
  // build your new name:
  // Here: second part[1]  first, then SpaceMinusSpace, then the first part[0]:
  FileName := Parts[1] + ' - ' + Parts[0] + WideExtractFileExt(FileName);
Spelling and grammar corrections allowed.
#5 2007-11-12 12:20
For this task, you can also use a simple RegEx rule...
Expression: (.*) - (.*)
Replace: $2 - $1
big_smile
#6 2007-11-12 12:57
I know and i know that you know tongue
But average user can't remember RegEx so they could just select an Script to do the same (and i imaging more to do with it)
