#1 2007-11-12 16:49
PascalScript: Browse Script question
Just a question since i find it in consequent:
- Add Rule > Pascal Script > Scripts > Browse Scripts..
With "Browse Scripts.." i get an explorer window with my script-folder only ?!?
And then? hmm
I think this option should be to open an script which lay not in my ReNamer\Scripts -folder? But elsewhere.
Am i wrong? roll
#2 2007-11-22 01:04
Re: PascalScript: Browse Script question
Yes, "Browse Scripts" option simply opens the directory where all saved scripts are stored, so you can easily rename, change, delete, or even create new scripts manually. If you need to import new script, then copy them into that folder, and they will automatically appear in ReNamer.
