#1 2007-12-05 18:35
ozzii
Delete last part
I try to do something, but no way to find.
Let's say that I have this kind of files:
"title.text1.text2.extension"
but I also can have this:
"title.text1.text2.text3.extension"
What I want to do it is to delete the last part behind the dot (without the extension).
So my result will be:
"title.text1.extension" for "title.text1.text2.extension"
"title.text1.text2.extension" for "title.text1.text2.text3.extension"
Please, somebody help me !!!! hmm
_________________
#2 2007-12-05 22:45
Re: Delete last part
Hi ozzii,
you could catch this with regular expression:
Find all till the second last dot     ==> (.+)\..+\.ext
So add an RegEx Rule
Expression:     (.+)\..+
Replace:          $1
[x]  Skip Extension
This means
.       ==> an dot find one char, no matter which
+     ==> find one or as many (greedy) of the same kind as the char before (any char in our case)
()     ==> group this to refer back to this find later
\.     ==> escaped dot, to find an dot by it self (and not "any char" as above)
+     ==> find one or as many of the same kind as the char before (any char in our case)
$1    ==> replace whit them found in expression group one
       ==> we didn't replace the rest..... so this is deleted
Note:
Greedy means "find/catch as many as you can" .... till the last dot in our case.
Try (.+?)\..+  where the ?-sign means "be non-greedy" and you will find all till the first found dot only.
HTH?
#3 2007-12-06 06:10
ozzii
Thanks Stefan.
I will test it this afternoon. So I will tell then if all is OK roll
Thanks.
P.S: I will love to know to use (a little more) RegEx wink
EDIT:
It's working !!! Thanks a lot
_________________
#4 2007-12-06 07:36
ozzii
One more question (for Stefan maybe).
How I can do to delete all the end of the name after the latest digit.
For example I can have:
text.100.text2.text3.text4.extension
text.text2.100.text3.text4.extension
text.100.101.text3.text4.extension
For result I will have:
text.100.extension
text.text2.100.extension
text.100.101.extension
Thanks in advance.
_________________
#5 2007-12-06 08:25
You are welcome. Great it works.
You have to find someone common in the file names.
Here you want to find an digit.
Then split your file name into parts:
ALL - Digit - Remnant.ext
To find any char use the RegEx .    (an dot)
To find all use the RegEx .+
To find one digit use \d
To find one or more digits use \d+
To back referencing later to this find you have to group the search by ()
To find all use the RegEx (.+)
To find one or more digits use (\d+)
Later you are able to get what your RegEx have found back by using an $1 for the first group, an $2 for the second,...
So try
Expression:  (.+)(\d+)
Replace:       $1$2
This didn't works ... you have to catch the hole file name:
To find the remnant use .+ again
So try
Expression:  (.+)(\d+).+
Replace:       $1$2
(since we didn't need the remnant after the digits later... we don't need to group this)
This didn't works ... the first .+ is to greedy. Use an ?-sign to be non-greedy
So try
Expression:  (.+?)(\d+).+
Replace:       $1$2
text.100.extension
Thanks in advance.
I have no time right now to test this much, but i think this should work.
CY
#6 2007-12-06 08:32
ozzii
YES !!!!! lol big_smile
This is it.
I was trying when you post your answer.
THANKS !!!! This is a really big help (for me at least) cool
PS: With your explanation, I begin to understand a little more RegEx.
_________________
#7 2007-12-07 13:39
Good man, Stefan! I appreciate your help with answering questions on forums! smile
Ozzi, just wanted to recommend a good place to learn RegEx: http://www.regular-expressions.info/
#8 2007-12-07 14:05
ozzii
Stefan (or someone else) , one more question.
When I have a filename (without the extension) who ended with a digit, last digit is deleted.
I try but with no success; is there a way to not lose the latest digit in this case?
Thanks again.
_________________
#9 2007-12-07 14:15
Can you post the exact RegEx expressions that you are using?
And few sample filenames, which do work, and which don't.
#10 2007-12-07 15:38
ozzii
Here it is wink
_________________
