#1 2008-01-31 02:29
LibertyToad
More EXIF information
This is a great program.  Have you considered adding support for full digital photo EXIF information (and maybe DNG image format support)?  There aren't very many re-namers that support full EXIF info and I've never seen any that support DNG.  This would make Renamer much more useful for photographers.
Thanks.
#2 2008-01-31 15:27
Re: More EXIF information
Thanks, LibertyToad smile
Regarding your question... What do you mean by "adding support for full digital photo EXIF" ? ReNamer already has support for EXIF in JPEG and some TIFF tags, through so called "meta tags" which can be accessed via Insert rule. To retrieve these tags, I use 3-rd party libraries, which are limited in terms of functionality. DNG's are in the same boat - I can add support for them, if only I can find some open-source libraries for Delphi, which I couldn't find by this day.
Nevertheless, you might be able to incorporate into ReNamer some other tools which can parse DNG tags. Have a look at these topics: PDF tags, Date and Time from RAW images - they describe how to use 3-rd party command line tools inside ReNamer.
#3 2008-01-31 15:31
I just looked at the Exiv2 tool used in Date and Time from RAW images topic, and guess what?! It can parse DNG tags big_smile
#4 2008-02-21 04:48
djcassar
Just another user here that would like the ability to get various EXIF information from the photo such as the shutter release number.
#5 2008-02-24 13:47
I can add any of these extra EXIF tags:
ExposureTime=1/8
FNumber=26/10
ExposureBiasValue=0/3
MaxApertureValue=28/10
FocalLength=580/100
Are they any use? Also, please advise on the alternative name for the needed tags...
