#1 2008-02-27 03:50
DroidDotBot
ReNamer for dummies??
ReNamer  - renamer for dummies is not listed on amazoin, or ebley ect so
hi sorry if all ready covered  but when your dealing with hundreds of files, all done diffently (mostly without ID tags):(
but mainly with common seperator [space][-][space] Can you assign $tring variable names (like old B.A.S.I.C.) ?
cd001-02 - the thin ice - the wall live in berlin.mp3
using the common seperator [space][-][space] or [" "+"-"+" "] and call it a$, b$ or c$ (or whatever)
for all 3 sets of data in this file-name ( cd#=cd$ - track=tr$ - album=al$ )  - - - AND actually swap them over !!!!
the wall live in berlin - the thin ice - cd001-02.mp3   - - for example or
the thin ice - the wall live in berlin - cd001-02.mp3   - - the thin ice - cd001-02 - the wall live in berlin.mp3
. . .  . . .. .. . . . . . . (seperators stay intact)  ????????????? need all 3 for corruption issues.
<been ripping since MP5/6/?, not always using MsMp's, but all are mp3's now!/? varied bitrates sad >
I understand the first string could be "track" OR "artist", or "cd-database.exe title seq" or even "untitled 15/03/1997" {{{that is what the state box is for use it B4 or not to obtain your desired outcome, look at the previews, when happy - rename }}}
P.S. analyze ?- actually stumps me - text {upper box} and {lower box} does'nt seem to differ ?
(is it me!! the faq's & tutor-al's are not for novices), OKAY the time to translate, combined with various languages both physical and machine code (Bolean, C and windows's other variables must be a real pain - donate!!! - - - better the places, where places are better) <:) <2nd post here>
sorry for rushing but have usually been [timed-out] on posts and reverted to other gnu/freeware support forums and again been (usually) [timed-out] will post again 2 your 'top 20 free good-stuff lists' comodopro2008
'<you may add, alter, edit move, start a new thread or delete , etc or any part of the above for the forums benifet, due to me @being a novice to structured forum searches, and not knowing the 'lingo'@>'
DroidDotBot U.K.
#2 2008-02-27 15:44
krtek
Re: ReNamer for dummies??
First of all... it's REALLY hard to understand what are you asking for.
If you want to change the filename of :
to something like this:
and that's all you want, you can do that with regex rule.
Expression: (.+)\s-\s(.+)\s-\s(.+)
Replace: $2 - $1 - $3
\s-\s - is you separator (you can probably use " - " instead, but I'm not sure
(.+) - are the parts of filename between separators (it means any char (".") repeated at least once ("+")
$1, $2, $3 - are parts of filename that match the content of brackets in expression "(.+)", numbered from left to right.
so if you want your output filename to be:
you need to put "$2 - $3 - $1" into Replace field.
#3 2008-02-29 01:42
DroidDotBot
yikes
okay  (hope this thin ice holds    big_smile)
to me is (.+)  is 'lets say' $A,
the 2nd (.+)  is B$, etc for third C$
the \s-\s  being seperator in my cace "[space]-[space]"
got that bit . but the rule addition maybe problematic
Expression: (.+)\s-\s(.+)\s-\s(.+) - - - - - - -  defines the s$'s and seperators, check
Replace: $2 - $1 - $3 - - - - - - - - - - - - - - -  bubble sort (1/2 pass etc?)
sad
now how do they translate into adding rules for a 'batch'
cool krTek
#4 2008-02-29 02:33
DroidDotBot
smile
Expression: (.+)\s-\s(.+)\s-\s(.+) - - - - - {strip rule?}
Replace: $2 - $1 - $3 - - - - - - - - - - - - - {replace rule?}
it's the syntax (is it all in one?) - - [Expression: (.+)\s-\s(.+)\s-\s(.+), Replace: $2 - $1 - $3]-replace rule?
create a string/value/field between seperators - are auto assigned? and how does the move work? (still close to zero big_smile )
thanks for the seperator- got the code there , but - - - the reordering/moving of @string values@ are getting to me sad
okay lets have a 101 for creating a 2 field file *.mp3 file {(ignore extension!!!!!!!!!!!!!!!!!!!!!!!!!)}
001 - paula abdul.mp3
I want to swap
001 <- - - - - - -> with paula abdul
so the file is - - - = paula abdul - 001.mp3     eg:- artist first, then track . mp3
p.s. www.computeractive.co.uk/2158522   found a very value-able tool (spellingz?) there! -> here!
#5 2008-02-29 03:23
krtek
I hope you are using the RegEx rule (not the Replace rule).
You have two fields to fill in that rule dialog:
Expression - which is "what are you want to find"
Replace - "what are you want to replace what you've found with"
If you want to learn more about regular expressions try ReNamer's User Manual (part Regular Expressions) or some tutorial like this:
http://www.regular-expressions.info/tutorial.html
I know nothing about batching in ReNamer, but I suppose you have to create a preset with set of rules and then invoke ReNamer with that preset as parameter...
Your 101 problem can be solved by RegEx rule:
Replace: $2 - $1
or
Expression: (\d\d\d)\s-\s(.+)
Replace: $2 - $1
Try to find out what does \d stands for...
And one more thing: in regex's (.+) is not referenced as $A or $B or anything else than $1-$9 (or \1-\9 in Pearl's notation)
so in expression: (boy)\s-\s(girl)
"boy" is stored in $1 reference
and "girl" is stored in $2 reference (as boy is FIRST from left, and girl is SECOND).
#6 2008-03-02 22:07
DroidDotBot
missed the regex in second post
add new rule ->regex
expression[.+]\s-\s[.+]\s-\s[.+]
replace $2 - $1
then new rule -> regex
replace $3 - $2
lol krTek big_smile
thank you for your help on this , may your god go with you
#7 2008-03-03 01:52
krtek
Well, I can't understand why you're using TWO regex rules.
You need just one.
Replace: $2 - $3 - $1
You can try to see what does changing "Replace" part for "$1 - $3 - $2" or "$3 - $1 - $2" and so on...
Then you can play trying something like this in Replace: "Second part: $2, and first was $1!"
And you CAN'T use square brackets for creating reference. Only round brackets correspond with $1, $2 and so on.
Square brackets do something completely different. Check the manual or tutorial for more info.
#8 2008-04-09 23:23
DroidDotBot
sorry for neglecting the support, of this valuable product, but been bleeding using it!!!!!!!!! big_smile
anyhoo   (after much time de-selecting huge folders worth of uslessley named files)
above/? post says why use 2/3 ? - some are just "track - artist"
M A I N - T H I N G - I S _ _ _ _ _ _ do a set of clean-up {routines}
if the seperators are incorrectly sourrounded with extra [space]'s -
        make a replace{argument?} and replace under scores with spaces ->all
        make a replace to get rid of "more than one space" too equal one space
I've had too move them up and down, on/off - this time = to get best result (percentage wise)
#9 2008-04-15 14:18
DroidDotBot, this a first and last warning!
You have to start writing in a proper and easily understood manner! Your words and sentances do not make any sense most of the times, and nobody can understand them. If you cannot do this your-self, then ask somebody else to write it on your behalf. I am sorry, but any future posts in the same format will be deleted, and can possibly get you banned from the site.
