#1 2008-04-12 17:27
gituncar
How add date format to end filename
How I do add date format to rename filename.
Example:
test.jpg - > test_yyyy-mm-dd.jpg or test_yyyy-dd-mm.jpg or test_yyyy-mm-dd_hh.mm.jpg  or  test_yyyy-mm-dd_hh.mm.ss.jpg
I need change date format.
#2 2008-04-12 18:32
eR@SeR
Re: How add date format to end filename
Welcome gituncar
First of all, read User Manual (8th - 9th page of pdf) to introduce with variables.
Then go to: Settings, Meta Tags.
In white field select date-time format you want to.
Click Add rule, Insert, Insert Meta Tag.
Choose between Date_Now, File_DateCreated or File_DateModified.
Select position in filename (in your case, suffix...) and that's it smile
#3 2008-04-15 14:27
He might have wanted EXIF_Date tag for JPEG files.
You can find it in the Insert rule, as eR@SeR have already mentioned.
The format for the date/time tags can be configured in the Settings.
#4 2008-04-15 14:49
eR@SeR
... or EXIF_Date as you said. To be honest, I use ReNamer mostly for songs (mp3s) so I didn't knew about it sad. Sorry if I wrong gituncar hmm
Edit: When we are talking about EXIF_Date, some of mine personal (taken) pictures won't display EXIF_Date as suffix. I saw in Properties, Advanced (win explorer) that both pictures have "Date Picture Taken". One shows EXIF_Date another doesn't. What could be the issue?
#5 2008-04-20 11:59
eR@SeR, can you send me a sample picture so I can experiment with it?
#6 2008-04-20 16:08
eR@SeR
Aha. Sent... wink
#7 2008-04-22 12:59
eR@SeR
Excellent work Denis. Now it reads just fine...
You're number one wink
#8 2008-04-22 14:28
I made it work, but didn't yet have time to tell you about it! wink
As you probably noticed, in the latest dev version, I've integrated dEXIF libraries to read EXIF Date from problematic JPEG files. It actually replaced the previously used libraries which failed to read EXIF section from that sample file you sent me. So give it a good testing now, ok?
#9 2008-04-22 15:28
eR@SeR
Yes, I noticed...
I'll do the testing for ALL taken images that I have, and if there is an issue, I'll let you know...
