#1 2008-05-17 09:42
ozzii
Rule for moving a part at the begining/end
I would like to know if it's possible to find a certain part and move it at the beginning/end of the file name ?
Explanation:
I have for example this:
aaa.bbb.100.TEST.ext
ccc.ddd.200.ext
I would like to have a rule for this, if there is TEST into the filename:
TEST.aaa.bbb.100.ext
ccc.ddd.200.ext (this is not changing because no TEST into the filename)
I do some more regex here and after a rule for moving the TEST at the end:
ccc.ddd.200.ext
So basically rules for:
- Find TEST and move to the begining
- Find TEST and move to the end
Any help ?
_________________
#2 2008-05-17 15:42
krtek
Re: Rule for moving a part at the begining/end
Hi Ozzi,
It is possible and it's quite basic. Here you go.
Both RegEx rules.
Moving TEST to the beggining:
Expr.: (.+)(TEST)(.+)?
Replace: $2$1$3
You can also ad space to seperate TEST from the rest; replace: $2 $1$3
Moving to the end:
Expr.: (TEST)(.+)
Replace: $2$1
In both cases you need to skip extention.
#3 2008-05-17 16:25
ozzii
So easy and basic tongue
But what can I do : I don't know Regex sad
But thanks to you all, I learn some things cool
_________________
#4 2008-05-17 17:26
krtek
You're misinforming tongue
Ozzi wrote:
I do some more regex here and after...
big_smile
