#1 2008-08-13 14:03
finwhale
Continue numbering images
Hi all - Hope this is the right place, i did post in the general section first of all. Is there a way to use this programme to re number files. I use a digital camera that numbers files 1 up to 9999 (eg dscn1, dscn2, dscn3 and onwards) when it reaches dscn9999 it re sets back to to zero, i would like to continue numbering the files from dscn9999 onwards eg dscn10000,dscn10001,dscn10002 etc etc, or perhaps start at a pictiure call it only by its number, 1 then 2,3,4,5,6 & so on indefinately, so when I take a card full of pictures the sequence can go on - I would need to have this done automatically because I take hunderes of pictures each day to do it manually would be an nightmare. Is this possible - many thanks
#2 2008-08-13 14:58
eR@SeR
Re: Continue numbering images
Hi finwhale and welcome to forum smile
With ReNamer "everything" is possible smile
i would like to continue numbering the files from 9999 onwards eg
when it reaches 9999 it re sets back to to zero
When it reaches from zero and so on 1,2,3,4,5...then you have dscn0, dscn1, dscn2, dscn3...Right?
If yes one solution could be:
1) Use Insert rule:
Insert: 1000
After text: dscn
Result is: dscn1      --->    dscn10001
              dscn9      --->    dscn10009
              dscn10    --->    dscn100010
              dscn99    --->    dscn100099
              dscn100   --->   dscn1000100
              dscn999   --->   dscn1000999
              dscn1000 --->   dscn10001000
              dscn9999 --->   dscn10009999
Click Rename!
2) Use Remove rule:
Remove: 0
Occurrences: [x] first
Then add your files from dscn100010 till dscn100099 to remove one zero surplus.
After that add your files from dscn1000100 till dscn1000999 to remove two zeros surplus (use duplicate Remove rule Shift+Ins).
And so on and so on...
It's not practical, but do the work roll
Second solution could be (even better), let me guess, to use PascalScript which I cannot help you about sad
Maybe someone can?  roll
#3 2008-08-13 15:01
krtek
Easiest way is to set flag "Use natural order sorting algorithm" in Settings/General, add files to ReNamer, sort files table by name and then add
two rules.
First:
for removing old numbers:
eg. Delete rule:
Position: 5 (or 1 if you wan't files to be named only with numbers, and get rid of dscn)
Until: till the end
Skip extention
Second:
Serialize rule
Incremental:
Index starts at: and here you put first number for that pictures set
Step: 1
Where: suffix
If you like you can use also "Pad to length" option
Then you click Preview, check if everything is ok in files table. And then press Rename.
Done.
#4 2008-08-13 16:50
finwhale
Thank you both so much I wil ltry out the suggestion by eR@SeR tomorrow. I have tried the suggestion by krtek  and it works great I just need to keep an eye on the next number to set when taking new photographs, what a superb programme I have been using rename up until now, but could not work this way of doing it. A contribution will be on its way via paypal soon.
#5 2008-08-17 19:09
Another idea would be to add all of your images and sort them by the EXIF Date column, and then re-number. This will ensure the correct chronological order.
