#1 2008-08-21 14:49
Read-only files should be renamed?
Detecting the read-only files to not rename it would slow down the program a lot?
and the same cuestion for that file.html + folder_ result of saving a web page with images (I don't know if I'm explaining it correctly)
I don't know where to post this, as it can be considered as a suggestion I'll leave it here
#2 2008-11-18 01:44
Re: Read-only files should be renamed?
It will surely try to, but Windows may block it. On my Windows XP it doesn't. Does your OS blocks it?
Yes, it can potentially slow down the renaming process.
and the same question for that file.html + folder_ result of saving a web page with images
I am not planning to support this officially, but there are homebrew scripts posted on the forum which can do this.
