#1 2006-05-25 12:56
KaptK
Renamer: Add Folder addition
An option to remove all the entries in the Treat Folder like Files dialog would be nice as I found if I added lots of folders then it was a bit hard to clear the entries quickly.
Either enabling you do a CTRL-A to select all entries then use DEL to wipe the folders and/or a button addition Remove All, would be really nice.
cheers
#2 2006-05-26 13:46
Re: Renamer: Add Folder addition
Good news KaptK, I've added both smile
Normally, I upload the dev version straight away, after few changes. I can't do it this time, because... Because ReNamer 4.00 is coming out soon big_smile
So you'll have to wait for the first Preview/Beta of the v4, to get your hands on the implementation of your suggestions. It's gonna be ready in few days, keep checking the news/forums...
#3 2006-05-27 16:03
_KaptK_
WoW! fast work and thanks smile
Looking forward to testing the new version as have loads of files here waiting to be renamed .. hehe.
