#1 2009-08-01 11:08
icerapids
Get AVI compression
hello all, i am new here so bare with me please, i just recently came across this program and cant say enough about it.. my friends are amazed at what it can do.. but ive recently ran into abit of a puzzle, i dont see an option in the AVI META to get the compression type of the file e.g. "XVID", "DIVX".. so my question is..   is there a way to pull such information from the file and insert it into a file or folder name with a script?
thank you in advance for reading and trying.  smile
#2 2009-08-01 13:23
Re: Get AVI compression
AVI is a container that can contain data streams encoded using many possible audio/video codecs. You can use the "detect using binary signature" rule or the TrID PascalScript to detect the correct file extension (i.e. AVI), but detection of the actual codecs used inside is not something I see being added anytime soon.
#3 2009-08-02 11:07
prologician
Wow, people still use AVIs... <LOL> wink
Well, with a little bit of online rummaging, I might have something for you. One thing I came across online (a rather cheap answer), is to read the four bytes from offset 0x70 in the file, according to one site. Assuming that the website is correct (something I'm not checking at this time), you can brew a short and sweet PascalScript to do the job:
  fourcc: string;
  if WideCompareText(WideExtractFileExt(FileName), '.avi') = 0 then
    fourcc := FileReadFragment(FilePath, 7*16, 4);
    FileName := WideExtractBaseName(FileName) + fourcc + WideExtractFileExt(FileName)
  end
Considering that Denis has already introduced metatags that tell the width, height, and framecount of an AVI, it's not a stretch that he could introduce support for FourCC as well. But at this second, I'm not sure we need to dump this one on him. smile
#4 2009-08-02 22:33
icerapids
BRILLIANT!!, thank you so much for your speedy replies..
Andrew: i tried that out.. and the binary signiture didnt make any changes to file name, i also took a look at the TrID PascalScript, and i have to say.. as much as i know about computers.. i was way in over my head..  i dont know Pascal, and ive been trying to learn it from the many examples i found on here and elsewhere.. but i am still very confused.
prologician: that script works GREAT!  smile   ..thank you so much, i have only to ask if theres a way to tweak the script abit..  for example.
the script does this..
Movie 1.avi  ->  Movie 1div3.avi
Movie 2.avi  ->  Movie 2xvid.avi
Movie 3.avi  ->  Movie 3xvid.avi
which is a great improvement from what i had before.. i can always add a few replace filters to clean it up abit, but i was wondering if you can possibly add a few things to the script itself so that the results could look like this..
Movie 1 Div3.avi  (would also be nice if it could auto rename results of div3 to DivX)
Movie 2 XviD.avi
Movie 3 XviD.avi
note: the space between the compression and the file name.. if this was added i think it would be an amazing peice of script i could use over and over again!  smile
#5 2009-08-02 23:35
If you want to replace "div3" or "div4" with "DivX", and "xvid" or "XVID" with "XviD" - simply add a couple of Replace rules. To insert a space in front of codec a small modification is required to the script, here it is:
  fourcc: string;
  if WideSameText(WideExtractFileExt(FileName), '.avi') then
      ' ' + fourcc + WideExtractFileExt(FileName);
  end
Note: This script may not work for all AVI files, depending on the structure of the AVI container.
#6 2009-08-03 01:57
icerapids
THANK YOU den4b!!!!!   big_smile:D:D   ..your program ROCKS dude!!!
i cant begin to tell you how amazing this is big_smile, and my appreciation for your knowledge has no bounds smile.. you guys are awesome..  with the push of a button, you saved me so many hours of work.   lol cool cool cool
works perfect!
#7 2009-08-03 03:05
narayan
If you are interested in the PascalScript, you can check out the new help here:
http://www.den4b.com/wiki/ReNamer:Pascal_Script
HTH
#8 2009-08-03 04:50
prologician
@Denis:
Among your metatags, you have some meant for AVIs, like digging up the framerate and framecount. Am I correct in assuming that you parse the AVI header (at the very least, the 'hdrl' chunk) to retrieve that data, as compared to a constant offset like what was used in this case?
(The reason I ask is that I'm thinking of writing an updated version which actually does things properly, rather than using magic numbers. If nothing else, the additional helper functions for handling endianness could come in handy some other day.) smile
Edit: I went ahead and cooked up something anyways. I think this is suitably more robust than the other code, since this allows reordering of the streams within the AVI (though isn't the video stream always first?), and properly jumps over the 'avih' main header (whose size is always constant, according to Microsoft spec). So, assuming that the video stream is always Stream 0 within an AVI, then yes... a constant offset could work. smile
If you're paranoid.... here's an alternative, with helper functions to match:
function BigEndian(const bytestring: String): Integer;
  i: Integer;
  result := 0;
  for i := 1 to Length(bytestring) do
    result := result * $100 + ord(bytestring[i])
function LittleEndian(const bytestring: String): Integer;
  i: Integer;
  result := 0;
  for i := Length(bytestring) downto 1 do
function FileAssertString(var offset: integer; const actual: string): Boolean;
  result := (WideCompareStr(actual, FileReadFragment(FilePath, offset, length(actual))) = 0)
  offset := offset + length(actual)
procedure FileSkip(var fileoffset: integer; const amount: integer);
  fileoffset := fileoffset + amount
function IsStrhVids(offset: integer): Boolean;
  result := false;
  if not fileassertstring(offset, 'strl') then exit;
  if not fileassertstring(offset, 'strh') then exit;
  FileSkip(offset, 4); //Size of the strh chunk
  if not fileassertstring(offset, 'vids') then exit;
  result := true;
  fourcc: string;
  fileptr: integer;
  streams: integer;
  chunksize: integer;
  i: integer;
    fileptr := 0;
    chunksize := 0;
    if not widefileexists(filepath) then exit;
    if not fileassertstring(fileptr, 'RIFF') then exit;
    FileSkip(fileptr, 4); //Size of the RIFF chunk (most of the file)
    if not fileassertstring(fileptr, 'AVI ') then exit;
    if not fileassertstring(fileptr, 'LIST') then exit;
    FileSkip(fileptr, 4); //Size of the list
    if not fileassertstring(fileptr, 'hdrl') then exit;
    if not fileassertstring(fileptr, 'avih') then exit;
    streams := LittleEndian(FileReadFragment(FilePath, fileptr + 28, 4));
    FileSkip(fileptr, LittleEndian(FileReadFragment(FilePath, fileptr, 4)) + 4); //Skip over the 'avih' chunk.
    for i := 1 to streams do
      FileSkip(fileptr, chunksize);
      chunksize := LittleEndian(FileReadFragment(FilePath, fileptr, 4));
      if IsStrhVids(fileptr) then
        fourcc := FileReadFragment(FilePath, fileptr + 16, 4);
        FileName := WideExtractBaseName(FileName) + ' ' + fourcc + WideExtractFileExt(FileName);
        exit
      end
    end
  end
This doesn't really address OpenDML standards, and I didn't really find a nice doc that explained it down to the nitty-gritty details like the regular AVI spec. If someone finds a nice spec that explains things well enough.... do tell. smile Otherwise, stick a fork in me, I'm done. smile
#9 2009-08-03 13:29
Very nice, prologician!! big_smile
But I have bad news for you: I have added AVI_VideoCodec meta tag! wink
Basically, this tag does exactly the same thing, but it will work faster than the script, it parses only the necessary structures and doesn't continuously opens and closes file (each call to FileReadFragment). It will also enumerate all available streams until it finds video stream, so video stream doesn't have to be the first one in the list.
By the way, I found a good AVI File Format Specification:
http://www.alexander-noe.com/video/docu … on/avi.pdf
P.S. AVI_VideoCodec is available in the latest development version.
P.S.2. prologician, you should add your script to wiki/ReNamer:Scripts, it can serve as a good educational example!
#10 2009-08-10 07:14
icerapids
MEGA SWEEEEET!!!  big_smile big_smile big_smile
