#1 2006-07-23 03:33
dbrename
Delete first 2 digits
I want to delete the first 2 numbers in a filename so as to make the list of filename entries uniform.
FROM: 1978_001 - Bee Gees - Night Fever (192S - 3.31)
TO: 78_001 - Bee Gees - Night Fever (192S - 3.31)
How?
Thanks, Don
#2 2006-07-23 03:41
Re: Delete first 2 digits
Hi Don smile
If you simply want to delete first 2 character, you can use Delete rule, and set it to delete from position 1 until count 2.
But if you want to remove first 2 characters ONLY if they are digits, then you need to use this script in the PascalScript rule:
  if IsWideCharDigit(WideGetChar(FileName, 1)) and
     IsWideCharDigit(WideGetChar(FileName, 2))
  then WideDelete(FileName, 1, 2);
#3 2008-02-27 21:54
krtek
You can use a RegEx rule as well:
Expression: ^\d\d(.+)
Replace: $1
And this freedom of choice is that what makes ReNamer so wonderful and powerful tool.
#4 2008-03-04 20:58
krtek, You are resurrecting a thread which is almost 2 years old tongue
By the way, with the latest version of ReNamer, script should be as follows:
  if IsWideCharDigit(FileName[1]) and
     IsWideCharDigit(FileName[2])
