#1 2010-01-04 18:06
karolisk
How to save renamed files in new folder?
should be simple, but I can't figure out how...
#2 2010-01-04 19:42
Re: How to save renamed files in new folder?
#3 2010-01-05 10:51
karolisk
thanks!
well, in general i understand this as "it's complicated".
my biggest problem is that when I rename files they have name collisions so I have to replace them and then manually take from backup copy and add replaced ones.
my point is, that there is no problem to move file to sub folder (just add 'subfolder/' before filename). So if this could be done only when the file is renamed it would be almost perfect.
#4 2010-01-05 13:20
I think Stefan misunderstood your question. He though you asked about copying files as opposed to renaming.
Renaming files into another folder is very easy, simply insert the folder name as "New Folder\" or "C:\New Folder\" in front of the filename using "Insert" rule.
#5 2010-01-05 16:10
Ahh! That was what 'karolisk' had modified at 05 Jan 2010  09:38 ...   big_smile
...he edited the subject of the topic, which was an part of the question (which is an bad behaviour anyway IMO)
FROM
how to copy renamed files in new folder?
TO
how to save renamed files in new folder?
#6 2010-01-06 13:40
