#1 2010-05-04 01:49
Markus
Exit after user cancelled an action
Hi there,
many thanks for this great program. It's kind of funny but it does exactly what neither Windows 7 or Norton Ghost can do - Hibernate a PC after a user defined amount of time. Great work, mate!
I've installed the latest Beta (3.00 Beta 37) and I haven't found a way to close the program after an action has been cancelled.
To give a brief explanation:
I run my nightly backup using Ghost and after the backup has finished Ghost calls Shutter which displays a message for 10 Minutes and hibernates the PC after this time. If I'm still working when the countdown starts I use "Cancel action" to leave the PC running. After that Shutter is still running (either visible or minimized) and because I've only allowed one instance of the program it has to be closed manually before it's possible to start the countdown again.
It would be great to have the option to shut the program down after a countdown has been cancelled.
Cheers -- Markus
#2 2010-06-03 13:46
Re: Exit after user cancelled an action
Try latest development version. I've added "Exit application" button to the Message action dialog.
