#1 2010-05-20 22:57
Serialize rule - reset counter for every n files
Maybe you like the idea to add this addition to the serialize rule?
(o) Incremantal: 1,1
[X] Reset every [   4] files
1
2
3
4 Reset
1
2
3
4 Reset
1
2
3.
EDIT: The script below is not needed anymore, because of:
ReNamer 5.50+ Beta 28 (~23.05.2010)
* Added option to reset serialization index every N files;
Till then we can use this ReNamer PascalScript:
Based on an script of Denis (http://www.den4b.com/forum/viewtopic.php?pid=1862#p1862)
  PADTO = 3; //amount of digits: 2=01 / 3=001 / 4 = 0004
  RESET = 9; //reset count every n amount: 4 = 1,2,3,4,1,2,3,4,1,2,3...
  Index: Integer;
  Value: String;
  Index := Index + 1;
  IF (Index > RESET) then
      Index := 1;
  Value := IntToStr(Index);
  if PADTO > 1 then
    while Length(Value) < PADTO do
      Value := '0'+Value;
  FileName := Value + ' '+FileName;
#2 2010-06-03 15:16
Re: Serialize rule - reset counter for every n files
I'm glad that you noticed the change already! smile
#3 2010-10-11 10:00
Related issue.
Often asked for: use the same counter for n files, then increase the counter.
e.g.
use the same counter '001' for 3 files, then increase the counter to '002' for the next 3 files:
a001.ext
b001.ext
c001.ext
d002.ext
e002.ext
f002.ext
Example code:
http://www.den4b.com/forum/viewtopic.php?pid=5011#p5011
But i have no good name found for this, only something like "serialize n files with the same count.pas"
