I think this could be related to a recent update on the file list, mentioned on this post.
http://www.den4b.com/forum/viewtopic.php?id=1014
The problem I'm having, is that when you do double click in the right edge of a column, it should be auto-resized.
But, in some columns it's resized an other columns resize not itself but other one next to it.
I think it's because I have some columns positioned on my own way.
To me it feels like the file list is some kinda messing position numbers with identifier ones. (Again I'm not programmer so i don't know if this have sense)
This is a bug in Virtual Treeview component. I have reported it to the developer.
In the meantime, I have implemented a workaround.
Try latest beta version...
ok, now it's working
