#1 2011-05-21 17:02
ozzii
Two sets of events with actions
First use of Shutter(beta), so don't be to hard.
I try to do this:
countdown 30s - turn off monitor
countdown 30min - sleep PC
I Have tried this (ALL) (tried also 1by1):
event:
Countdown 30S
Countdown 30m
action:
turn off monitor
sleep
After 30S the monitor is not turned off!!!
I thought tha I can put several events/actions for doing ALL one after other.
Did I must to create 2 separates presets!?
I think I didn't found how shutter works ;(
_________________
#2 2011-05-21 17:11
Re: Two sets of events with actions
Maybe the wiki can help you?
http://www.den4b.com/wiki/Shutter
#3 2011-05-22 08:59
ozzii
I have read the Wiki before my post but didn't help.
In the example there is 1 event and 2 actions... But me I have 2 events and 2 actions ...
_________________
#4 2011-05-25 12:39
Shutter concept is as follows: monitor events and execute list of actions when conditions of events are met. This means that there is only one flow of execution and no way of separating which actions get executed for which events. This is a limitation of the current design.
You need to create two presets and lunch two instances of Shutter each running one of those presets.
#5 2011-05-25 12:52
ozzii
This is what I thought  wink
Thanks for the confirmation.
I will create 1 preset for each event.
_________________
