#1 2011-06-18 12:27
Enrico65
Renaming progress status
I am using ReNamer in this very moment to serialize the filenames of a folder which contains some 20'000 files.
To improve the performance, I had to disable "Validate new filenames on preview" and "Real-time update of the preview".
- There is no way to know the present status of the renaming process
  (something like at least one of the following: "Now renaming file: 2'000 of 20'000,  (10% done), [progress bar], 18'000 items remaining...).
  I can only wait for the operation to end.
- There is no way to stop the program (with very large file blocks it becomes non-responsive until it ends), apart from killing the process, which is not the best thing to do...
#2 2011-06-20 10:53
Re: Renaming progress status
This is a known issue. The only way to address this is by rewriting the core in a threaded manner, in order to allow asynchronous renaming and GUI updates. Unfortunately, ReNamer was designed a long time ago and being a threaded application was not part of the design at the time. I have this task noted for the future but cannot commit to it right now.
#3 2011-06-20 11:39
Enrico65
I understand and wait!
All the best, Den!
#4 2011-06-20 17:12
Meanwhile, I'll just point that (at least in XP) if the window is minimized, the real-time preview doesn't slow down the process.
