#1 2011-11-05 09:17
askswap
Shutter v3 Beta does not display time left in tray
How to active time left in tray as seen on this screenshot and/or disable running for?
?x=get&product=shutter&type=thumb&index=4
#2 2011-11-06 16:24
Re: Shutter v3 Beta does not display time left in tray
The first screenshot is from version 2.xx, where you can only have 1 event at a time. This made things easier because the amount of text which can be displayed in the tray icon tip is very limited (64 characters for the tool tip). In version 3, we have unlimited number of events and it is it impossible to fit status of more than 1 event in the tool tip.
I made a compromise. If only 1 event is running, you will see the status for that event, otherwise, a general status with the running time will be displayed.
Download latest development version.
#3 2011-11-06 20:36
askswap
Thanks!
