Started using this program with great pleasure but i have a question. How can i capitalize the first letter from each word between brackets?
Ex.
I can only imagine (feat. chris brown and lil wayne)
To:
I can only imagine (Feat. Chris Brown And Lil Wayne)
Thanks for the help.
Hi and welcome.
I can only imagine (feat. chris brown and lil wayne).ext
To:
I can only imagine (Feat. Chris Brown And Lil Wayne).ext
Yes, unfortunately there is no easy solution.
The Case Rule could have an "apply to that part"-regex option, but the developer has not much time.
But we can use an PascalScript for such issues.
Read our wiki how to use an PascalScript > http://www.den4b.com/wiki/ReNamer:Rules:PascalScript
(thanks to the wiki maintainers)
and then use e.g. this code:
iPOS:integer;
Base, Part1, Part2:WideString;
Base := WideExtractBaseName(FileName);
iPOS := WidePos('(', Base);
Part1 := WideCopy(Base, 1 , iPOS -1);
Part2 := WideCopy(Base, iPOS, 999 );
FileName := Part1
+ WideCaseCapitalize(Part2)
end.Now i have seen i had not exactly follow your wish "between brackets", because this script just takes all
from the first open '(' parenthesis to the end. but since it works for your provided example file i guess it is ok?
If not use this code:
Parts: TStringsArray;
// match the string between the first found parenthesis:
// Example: I can (feat. chris brown) (remix).ext
// The RegEx splits the base name into:
// Part1: "I can "
// Part2: "(feat. chris brown)"
// Part3: " (remix)" //if any part3
Parts := SubMatchesRegEx(WideExtractBaseName(FileName), '(.+?)(\(.+?\))(.*)', FALSE);
If (Length(Parts) <=0) then exit;
//Part2 is case changed:
Parts[1] := WideCaseCapitalize(Parts[1]);
//New Name:
FileName := Parts[0] + Parts[1] + Parts[2] + WideExtractFileExt(FileName);
end.In ReNamer click at [Preview] and see how it works for you. If it works please help Denis too.
Maybe this is not very relevant but I made a modification to search recursively for brackets in the last part of the string.
Just for fun:
function CapitalizeBetweenBrackets(S: WideString): WideString;
var Parts: TStringsArray;
// Divide the string in parts
Parts := SubMatchesRegEx(S, '^(.*?)(\(.+?\))(.*)$', false);
if (length(Parts) = 3) then
// Capitalize the part between brackets
// Check again for brackets in the third part.
if (Parts[2] <> '') then
Parts[2] := CapitalizeBetweenBrackets(Parts[2]);
// Join the parts
Result := Parts[0] + Parts[1] + Parts[2];
end
else
// If no brackets found return the string unchanged
Result := S;
FileName := CapitalizeBetweenBrackets(FileName);
end.If this software has helped you, consider getting your pro version. :)
Thanks a lot, it's working like a charm!!!!
