#1 2012-09-27 13:51
Alert on /rename with non existing preset
Some days ago I decided to move all my presets out of the preset folder just to clean it.
The case is that I didn't bring back all of them, and one that I used via /rename command was missing.
And this was the message that I got when trying to rename with it: "new names are empty".
I think the message of the error it's not clear enough, and would be a good idea to warn that the preset doesn't exist.
#2 2013-06-07 11:05
Re: Alert on /rename with non existing preset
Just noticed this post. I'll look into it.
#3 2014-04-21 17:56
This issue has been fixed in ReNamer v5.75.1 Beta.
* Display a warning message when trying to load a non-existent preset file;
* Cancel command line renaming mode when preset file does not exist, instead of silently using the default preset;
