#1 2013-03-19 23:09
New releases: Colors and RandPass
These tools have been in the development stage for quite some time, going through testing phases and slowly maturing. They have finally reached the release stage!
Colors v1.0.0.0
Color picker that helps you easily select a desired color using various pallets. It is also able to pick a color from the currently displayed screen content and supports a number of different color models, i.e. RGB, HSV, HLS, CMYK.
RandPass v1.1.0.0
Random password generator. Simple tool for generating random passwords based on specified character set with customizable output format. User can easily select groups of characters used for password like lower case letters, upper case letters, digits, specify custom character set and formatting of the password, check for uniqueness, eliminate similar characters and much more. Application also supports command line execution for unattended generation of passwords.
P.S. Currently only portable/archive versions are available and the installer versions will follow later once I implement the storing of settings in the common public folder instead of the installation path to be compatible with User Account Control (UAC).
