#1 2014-04-10 13:53
Xbon
Rename Using Folder Name
Trying to rename 600 movie files using the folder name.
Ie
Folder name is Arthur (2011)
File is Arthur 720p.mkv
So i want the new file to be named Arthur (2011).mkv
Tried a few suggestions from the search and it doesnt work for me..
any ideas guys
#2 2014-04-10 17:09
Re: Rename Using Folder Name
You can simply insert ":File_FolderName:" meta tag, but don't forget to delete the old name prior to that.
1) Delete: Delete from Position 1 until the End (skip extension)
2) Insert: Insert ":File_FolderName:" as Prefix (skip extension)
For the reference:
* http://www.den4b.com/wiki/ReNamer:Rules:Insert
* http://www.den4b.com/wiki/ReNamer:Meta_Tags
