Hello
The Email_DateSent metadata item for EML files appears to return the time one hour earlier than the actual email time
Outlook_DateSent (the equivalent for MSG files) appears to be OK though.
Please provide sample emails, in both formats.
Email address can be found in the About dialog in ReNamer.
Samples sent.
Thank you for samples.
Indeed there was a problem with incorrect timezone adjustment for Email_DateSent and Outlook_DateHeader meta tags, causing dates to be UTC instead of local timezone in some cases. Outlook_DateSent meta tag was not affected.
This should be fixed now, you can try the latest development version:
http://www.den4b.com/?x=get&product=renamer&type=beta
Thank you for your fast response and solution to this problem.
