#1 2014-12-15 09:56
chuan0326
How to get rid of (), any string in any position
After feeling very convenient to use, thank you.
To ask you some questions, such as:
Admit (KTV) Terry Lin (Li Lin) .MPG
This arrangement is the song _ singer, is there any way to change
Terry Lin _ admit .mpg
What is the method to get rid of at any position in line with the string
For example, I want to get rid of this (), any string in any position
#2 2014-12-15 21:49
Re: How to get rid of (), any string in any position
Normally, to get rid of "(...)" everywhere you can use Strip rule.
But in your case you need to use the following rules:
1) RegEx: Replace expression "\(.*?\)" with "_" (skip extension)
2) Strip: Strip trailing characters " _" (skip extension)
3) Rearrange: Split by exact pattern of delimiters " _ ", New pattern "$2 _ $1" (skip extension)
Input:
Output:
  Terry Lin _ Admit.MPG
#3 2014-12-16 14:01
chuan0326
First of all, thank you for your guidance.
Sorry, wrong is following as the last son.
I will not be set, as shown.
Also, if you want to change this format more
KTV-Mainland singer Zhang Yiwen --- next life you have to find (MV)
File name is not (), setting an arbitrary string anywhere screening
Thank you
#4 2014-12-17 00:07
Unfortunately, I don't understand what you are saying...
By the way, you need to use spaces in both " _" and " _ " patterns, which you don't seem to have in your rules.
#5 2014-12-17 00:45
chuan0326
Sorry, I mean yes.
1.For example: xxx_xxxxx-xxxx-.mpg
    string xxxx stands for "string", screened at any place at any of, and "_" and "-"
    How to set
2.Any other way anywhere in any Chinese filter string
   Trouble illustration
Thank you again
