#1 2015-11-26 12:52
bubbles15
Regular expression is returning literal replace option
Hello, I apologise for my ignorance here:
I'm trying to use a regular expression to replace instances of 1-99e with 1-99x, as that's the format my nieces want.
Using a regex replace  I've tried to do: Expression (\d)e and replace (\d)x, yet when running, Renamer returns the literal replace, so instead of 4e99 becoming 4x99 it becomes (d)x99.
I would be very grateful if someone would kindly point out where I am going wrong.
Is there a simpler 'Replace' rule I could use, that looks for a number and changes the text after it?
Many thanks.
#2 2015-11-26 17:21
Re: Regular expression is returning literal replace option
Hello.
It looks like you are using a Replace rule, which doesn't work with regular expressions.
You should use a specialized RegEx rule, like below:
RegEx: Replace expression "(\d)e" with "$1x" (skip extension)
#3 2015-11-27 12:03
bubbles15
Many thanks, that worked beautifully.
