Peace be upon you all
I would like to rename all the files in a directory (and even the folder names) if and only if their length exceeds 30 characters
How can I do that?
Also I would like to check the full path, if it exceeds 200 char, it should do some rules like remove vowels from each part of the path
Can this be done, and how?
Many thanks in advance...
You can use the context menu of files table to select items which exceed a certain size. Then invert the selection and remove those files.
You can check full path length in PascalScript and perform pretty much any operation from there.
You could also use a PascalScript rule to insert a marker into files which you can then easily remove from the list using the same context menu of files table.
