#1 2016-12-30 08:05
skylinekiller
Rename formula for dates
How can I get the following to look like the following?
Asot752 - 25-02-2016 - A State of Trance 752 (SBD), Armin Van Buuren
This is what I want
ASOT 752 (2016-02-25)
#2 2016-12-30 11:18
Re: Rename formula for dates
What have you tried so far?
These rules will work for your example:
1) Replace: Replace all "Asot752 -" with "ASOT 752" (skip extension)
2) Reformat Date: Convert to "yyyy-mm-dd" from "dd-mm-yyyy", whole words only, skip extension
3) Regular Expressions: Replace expression "\b(\d{4}-\d{2}-\d{2})\b" with "($1)" (skip extension)
4) Delete: Delete from Delimiter " - " until the End (skip extension)
#3 2016-12-30 12:04
skylinekiller
The Asot572  have many different versions example
Asot573
Asot574
Asot600
#4 2016-12-30 12:21
skylinekiller
Here is what I am trying
Asot expressions
#5 2016-12-30 12:36
Asot752 - 25-02-2016 - A State of Trance 752 (SBD), Armin Van Buuren.ext
ASOT 752 (2016-02-25).ext
THAT IS:
Take first word, split at first digit and insert space, upper case.
Take first three standalone digits and order the parts, put parentheses around.
Drop the rest.
USE RegEx Rule:
Expression: Asot(\d+) - (\d\d)-(\d\d)-(\d{4}).+
Replace: ASOT $1 ($4-$3-$2)
#6 2016-12-30 12:47
skylinekiller
Ok, here is the latest.  Not sure if this is the "real" way to do this, but I am achieving what I want.  This is pretty complicated to understand.   How can I get rif of the hyphen between the episode and date  example
ASOT 754 - (
to
ASOT 754 (
latest
#7 2016-12-30 12:48
skylinekiller
Nevrmind, I just replaced
with
#8 2017-01-02 09:52
skylinekiller
I stumbled onto another issue with similar files.  I am trying to rename 200+ files with the below file names.  I cant's seem to get it to work with labeling the "parts"
01-armin_van_buuren_-_a_state_of_trance_008_(id-t_radio)_03-08-2001-tt       I want ASOT 008 (2001-03-08) Pt 1
02-armin_van_buuren_-_a_state_of_trance_008_(id-t_radio)_03-08-2001-tt       I Want ASOT 008 (2001-08-03) Pt 2
01-armin_van_buuren_-_a_state_of_trance_025_(id-t_radio)_06-12-2001-tt       I want ASOT 025 (2001-12-06) Pt 1
02-armin_van_buuren_-_a_state_of_trance_025_(id-t_radio)_06-12-2001-tt       I want ASOT 025 (2001-12-06) Pt 2
#9 2017-01-02 15:38
01-armin_van_buuren_-_a_state_of_trance_008_(id-t_radio)_03-08-2001-tt.ext
02-armin_van_buuren_-_a_state_of_trance_008_(id-t_radio)_03-08-2001-tt.ext
01-armin_van_buuren_-_a_state_of_trance_025_(id-t_radio)_06-12-2001-tt.ext
02-armin_van_buuren_-_a_state_of_trance_025_(id-t_radio)_06-12-2001-tt.ext
ASOT 008 (2001-08-03) Pt 1.ext
ASOT 008 (2001-08-03) Pt 2.ext
ASOT 025 (2001-12-06) Pt 1.ext
ASOT 025 (2001-12-06) Pt 2.ext
THAT IS:
- take and store the leading number (but no zeros) as $1.
- take and store number behind 'trance_' to $2.
- take and store three groups of digits before '-tt' to $3, $4 and $5.
New Name:
- Add prefix 'ASOT '
- Add stored digit group $2
- Rearrange the three digit groups and surround by parentheses: ($5-$4-$2).
- Add ' Pt '
- Add stored number $1
USE RegEx Rule (http://www.den4b.com/wiki/ReNamer:Rules:RegEx):
Expression: ^0*([1-9]+).+_trance_(\d\d\d)_.+(\d\d)-(\d\d)-(\d{4})-tt$
Replace: ASOT $2 ($5-$4-$3) Pt $1
[x] Skip extension
#10 2017-01-03 00:43
skylinekiller
That seemed to work perfectly.  but I had about 50 of each that had a slightly different name set up and I didn't notice it until now
01_armin_van_buuren_-_a_state_of_trance_193_21-04-2005-tt
01_armin_van_buuren_-_a_state_of_trance_264_(di.fm)_2006-08-31-tt
I am still trying to get the the same output "ASOT ### (yyyy-mm-dd) Pt #.ext"
I fee like that expression you gave is is some secret formula to build a time machine... lol
