#1 2018-01-24 22:02
kayten
Can't Shutter run or reset automatically?
Hi, I'm still new to Shutter and I wonder if someone can help me out with this.
I've set it up to close a program after a set time (15 mins, in this case). But I have to set it to run, and then, if the program closes down and I restart it, I still have to set it to run.
Isn't there a way to make it just put that into effect automatically? It would be so much better if, once I'd used the program, the clock would start again automatically. If I forget to start Shutter manually and leave my desk, the program will stay open just the way it used to, before I had Shutter.
Or am I missing something obvious?
#2 2018-01-24 22:10
Re: Can't Shutter run or reset automatically?
Maybe you are looking for something like this...
Events [1BY1]:
1) Process: Starts "MyProgram.exe", check every 5 seconds
2) User Inactive: Inactive for 0:15:00 using Last Input Event
Actions:
1) Kill Process: "MyProgram.exe"
2) Utilities: Restart events
#3 2018-01-25 18:58
kayten
Perfect! Thank you! If I seem a bit slow, it's because my brain's been affected by a condition I have, things are much harder for me to grasp sometimes these days.
Another question: I don't seem to be able to use Shutter for more than one task ... if I start to create a new one, the original one disappears. I know I'm limited with the trial version to 5 tasks/operations, but I seem to be limited to just one in reality. Or am I once again missing something (probably something obvious)?
#4 2018-01-26 13:53
You can save your configuration (events and actions) in a preset, which you can then load at any point to use the same setup. A single instance of Shutter can only run a single set of events and actions at a time. However, you can use multiple instances of Shutter and run several different and independent configurations at the same time.
The free version of Shutter has a few limitations, including a maximum of 5 actions and 5 events at any one time.
#5 2018-01-26 18:00
kayten
Thank you for the info. I'm starting to understand this (I think!).
It's certainly a very clever and capable piece of software.
