#1 2020-04-22 15:27
Bayleyvilla
Stay awake during windows updates
Greetings.
I use shutter very simply no user interaction for 1 hour then shutdown.
What I would like is to keep that but make it pause during file download of windows update.
Any help please.
Regards
Alan
#2 2020-04-22 17:40
Re: Stay awake during windows updates
You could try using a combination of 3 events, for example:
1) User Inactive: Inactive for 1:00:00 using Last Input Event
2) CPU Usage: Below 10% for 600 seconds
3) Network Usage: Below 10 KB/s for 600 seconds
These should be used with "ALL" logic to achieve the desired effect.
You will probably want to play around with the specific parameters to make sure it works for you.
#3 2020-04-23 10:18
Bayleyvilla
Wow. Thanks for the great answer, worked as you said it would no alterations required.
Now may i ask another question:
email client's polling for emails, this resets the counter any way round this.
Regards
Alan
#4 2020-04-24 18:44
You could quit the email client wink
Alternatively, you could try monitoring for a Windows Update related process, or maybe scheduling it at other known times.
