#1 2020-05-24 16:22
mxmjykoj2
How to rename Unix Time Stamp name to readable date time format?
I got lots of files named as:
I had inspect the rules, finally I goes to 'Pascal Script'.
(If there is more simple way to achieve this with other Rules, please let me know. thanks.)
here is my current progress:
  FileName := DateToStr(
    UnixToDateTime(
      StrToInt64(FileName)
end
Tried to compile, it give me error 'period ('.') expected', and during my 2 hours work, there was also lots of 'type' errors as well.
I am not familiar with programming, this is first time to do with Pascal, I am quite confusing, so would like to ask help from here,
anybody can sort this script out for me?
thanks.
#2 2020-05-24 17:14
Re: How to rename Unix Time Stamp name to readable date time format?
Hi and welcome.
Very well done so far, congratulations.
'period ('.') expected' probably refers to the missed dot which is mandatory for the last "end".
You have to know that the variable "FileName" contains, well, the file name, which is like "1590333218.jpg"
And "1590333218.jpg" is no TDateTime but an string with dot and extension.
So try to work with the base name "1590333218" only.
See http://www.den4b.com/wiki/ReNamer:Pasca … :Functions
WideExtractBaseName(FileName)
WideExtractFileExt(FileName)
USE:
    UnixToDateTime(
      StrToInt64(
But "DateToStr()" is not the right one for your wanted result 'yyyymmdd_hhmmss', because the description reads
like "Converts a date to a string, using system format for the short date, for example: dd/mm/yyyy"
Unfortunately, I don't know which function else to use, I have to try that first with the functions from
EDIT: got it
//function FormatDateTime(const Format: String; DateTime: TDateTime): String
//myString  := FormatDateTime('yyyymmdd_hhmmss', <here an TDateTime>) ;
    FileName :=
      FormatDateTime(  'yyyymmdd_hhmmss' ,
        UnixToDateTime(
          StrToInt64(
Code cleaned up for others with explanation:
Use PascalScript
http://www.den4b.com/wiki/ReNamer:Rules:PascalScript
PascalScript code:
  myBasename,myDateTime:WideString;
  myUnixTimeStamp:TDateTime;
  //filename is like "1590333218.jpg" , basename is an Unix Time Stamp like "1590333218"
  //"1590333218" should result to "05/24/2020 @ 3:13pm (UTC)" (see www.unixtimestamp.com/)
  myBasename := WideExtractBaseName(FileName);
  //function UnixToDateTime(U: Int64): TDateTime; 	Converts a Unix timestamp to a value of TDateTime type.
  myUnixTimeStamp := UnixToDateTime(   StrToInt64(myBasename)   );
  //which results for "1590333218" , format to 'yyyymmdd_hhmmss' , as "20200524_151338"
  myDateTime := FormatDateTime('yyyymmdd_hhmmss', myUnixTimeStamp);
  FileName := myDateTime + WideExtractFileExt(FileName);
//--or something like this, if somebody want:
FileName := myBasename + '_(' + myDateTime + ')'   + WideExtractFileExt(FileName);
// >> 1590333218_(20200524_151338).jpg
FileName := myDateTime  + '_(' + myBasename  + ')' + WideExtractFileExt(FileName);
// >> 20200524_151338_(1590333218).jpg
#3 2020-05-25 07:50
mxmjykoj2
Wow! Thank you very much, that's the best answer I've ever gotten in cyber! I love your software and your personality!
I do expect more software you can provide, but I will definitely buy when I need it.
You're a star!
