#1 2020-06-09 08:44
xyberz
How to put a year inbetween parenthesis? e.g. 2020 > (2020)
Tried searching to see if anyone had already posted something similar and couldn't find anything so hopefully you guys can help with the right way to do this.
Basically just looking to put a year in a filename into parenthesis.  Example below:
Testing file 2020.rar
to
Testing file (2020).rar
#2 2020-06-09 14:45
Re: How to put a year inbetween parenthesis? e.g. 2020 > (2020)
Hi and welcome.
Question: is that always only ONE number in your filenames,
and / or always the last part before the extension dot, and / or always exactly 4 digits?
Then you could use the below Regular Expression rule
USE:
Regular Expression
Search: ^(.+) (\d\d\d\d)$
Replace: $1 ($2)
[x]skip extension
#3 2020-06-09 22:39
eR@SeR
Hi.
Similar question has been posted here Regex match before / after?.
